Timeline progress bar to scale consistently between all events
For mobile devices, the timeline bar will display as an oval for some events but as circle for others. This isn’t an issue for desktop devices. I would like the progress bar to display as circles across all events. Here is an example:
Hi there, @andrewchin :waving_hand:
I’ve passed it on to the devs and will update you once it’s fixed :slightly_smiling_face:
Thank you Max, I really appreciate it!
This issue appeared because of the .global-styles, element used in the CSS code of your Popup widget. I’ve removed .global-styles, and the markers are displayed correctly now.
Please check it out and let me know if it’s fine on your end now :slightly_smiling_face:
Beautiful! Everything looks great on my side. Also, now images are consistently the same size which is amazing. Thank you again Max!
It’s my pleasure :wink:
