Timed popup
hi there,
we just created a new form and the setting seems to be embed rather than popup. Can we set it as a popup or get that on the form?
Edward
Hi @Edward_Nugent
I think you mean a form in a popup ??
Use this and set up your form as a popup.
Popup Widget
Hey there, @Edward_Nugent :wave:
Yep, as Sina mentioned, our Popup app has a Form block with the necessary fields for your case:
Give it a shot and let us know if it worked for you :slightly_smiling_face:
