Text “This field is required” is not translated into Dutch.
Text “Please fill all the required fields” is not translated into Dutch.
For the text “This field is required” seems to be an entry in the ‘Edit texts’
in the language-section, but this is not picked up in the widget.
For the text “Please fill all the required fields” is no entry in the ‘Edit texts’
in the language-section.
Max
3
Hi there, @user21337 and welcome to the Community
Thanks for bringing this to our attention!
I’ve passed this issue on to the devs and will get back to you once it’s fixed
Thnx for your quick reply and hereby excuses for not stating my name
when posting this bug/issue.
Kind regards (while awaiting a fast and optimal solution, as always
André van der Rijt
Max
5
Worry not! The fact you’ve found this bug is the most essential (thanks a lot, again) and stating the name isn’t a necessary step for this
Max
6
The issue has just been addressed. Please check your widget and let me know if everything is fine now
Finally had time to check the widget and …
PROBLEM = SOLVED
Thnx to the Elfsight-Team.
Max
8
Great, you’re always welcome
