I’ve been using the Team Showcase module on the following link: https://www.fmgroup.fm/en/brands. It used to display three cards in one row, but it seems the layout has changed to two cards per row now. How can I change it back to three cards in a row? Thanks in advance!
Hi there, @Fleur_Alleman ![]()
For this, you should slightly increase the width on the Layout tab:
This worked, thank you
No sweat ![]()
