TaskRabbit reviews
Share your use case and provide as many details to support your idea as possible:
could you please add task rabbit reviews as an option to embed.
@Shaun1 thanks a lot for sharing your request, and welcome to the Elfsight community!
We’ll try to consider Task Rabbit reviews in our future updates, I’ll keep you in the loop :slight_smile:
Thanks a lot for your help!
I’m commenting to stay looped in. This would be great for my brother!
Hi there @user10856 :wave:
Thank you for the feedback!
While this option isn’t supported, you can try to add your reviews manually using the Custom Source option. Feel free to check it out :wink:
