Tags/labels widget
Request for new feature.
Basic features
Create your own product labels.
Set your own text, color, shape, position and animation of the label.
Option to automatically display percentage discounts (from the crossed-out price)
Automatic display of labels for products according to set rules.
Option to create multiple labels and rules for different product types.
Easy management via an external configurator without interfering with the e-shop template.
Automatic insertion of functional code into the e-shop via the Eshop-rysle API.
Suitable for highlighting promotional, seasonal or important products. Automatic removal of the inserted code when the add-on is deactivated.
Introducing the application
The Advanced Product Labels application helps e-shops to present important products more prominently using their own visual labels. Thanks to labels, you can quickly show customers which products are new, discounted, recommended, seasonal or otherwise exceptional. Labels are displayed directly next to the products and help customers navigate the offer faster.
Tags
Welcome to the community, @Jaroslav_Nesleha, and thanks a lot for sharing your suggestion and all the use case details!
I really like the idea of using custom labels to highlight specific products and make important offers easier to spot :slight_smile:
Let’s see what other community members think about it!
