It’d be great if we could select categories directly in an opened image popup. Right now, you can only enable/disable the category display for popup, not switch between categories.
Thanks for sharing your suggestion, @Marketing15, and welcome to the community! ![]()
An option to change categories is popup sounds interesting! Do you envision it having the same buttons in the popup, or do you have other ideas?
Thank you for your help! ![]()
