Submission ID on forms?
I’d like to to be able to use forms with attachments to create support tickets. Is there a way to have the forms generate unique submission ID’s?
Example:
Customer submits question to support.
When they hit submit, a submission ID is generated for that ticket, visible to both user and backend support staff.
Hi @user887 and welcome to Community :tada:
I think your idea is really great! We’ll take it under consideration in our future updates.
Please do not worry, we’ll keep you in the loop here :slightly_smiling_face:
Hi @user887 ,
maybe this is a solution for you. I use it myself.
Create Ticket ID
@Sina Thank you so much for your note!
I guess the solution given in this topic would be more suitable for this case :slightly_smiling_face:
@user887 Could you please check it out and let us know if it worked for you?
