Hello Team ![]()
Thank you for making the Stripe integration feature.
Rather than just having fixed price/ subscription for options, restaurants will really benefit from allowing the price to be selected per guests.
For example, charging $10 per guest as a setting, so when 5 people are selected, we can charge $50 via Stripe. It will also be even more detailed if there is a field (x) that can set the minimum number of guests so customer group under x number of people can be exempted.
Thank you for your consideration ![]()
