Please, add this feature so that we can see what is the conversion rate of the spinner! We need to see if the user submitted it on a phone or desktop. Also, which pages converted best.
Hi there, @user527 ![]()
Nice idea! We’ll have it in mind and see what others think about it.
By the way, I guess it’s possible to track clicks on the wheel and its form buttons. If you’re interested in this feature, I can discuss it with the devs for you ![]()
Great! This way it can easily shows the conversion rate, too ![]()
Our devs came up with the Google Analytics code for you. Please add this part of the code to your website <head>:
<script async src="https://www.googletagmanager.com/gtag/js?id=UA-ID"></script>
gtag('js', new Date());
gtag('config', 'UA-ID');
And then just add the rest of the code to the Custom JS field on the Settings tab of your widget’s settings:
const EVENT = 'click';
function eappsDispatchAnalyticsEvent(config) {
function sendEvent(config) {
if (typeof ga !== 'undefined') {
ga('send', 'event', {
eventAction: config.action,
eventLabel: config.label,
event_label: config.label,
sendEvent(config);
document.addEventListener(
'click',
function ({ target }) {
if (!target.closest('[class*="eapps-spinning-wheel"]')) {
return;
const isWheel = target.closest('[class*="sector__Content-sc"]');
const isSpinBtn = target.closest(
'[class*="init-content__FormContainer-sc"] [class*="ButtonBase__ButtonContainer-sc"]'
const isNoThanksBtn = target.closest('[class*="content__Decline-sc"]');
if (!isWheel && !isSpinBtn && !isNoThanksBtn) return;
const label = isSpinBtn
? 'Spin button'
: isNoThanksBtn
? 'No,thanks button'
: 'Wheel';
eappsDispatchAnalyticsEvent({
action: EVENT,
category: 'Elfsight Spinning Wheel',
label,
true
In Google Analytics, you’ll receive events with the name Click (in event label, you’ll see which element was clicked). If you wish, you can change the name of the event in the 1st line if the 2nd part of the code:
Try it out and let me know if it worked ![]()
Status Update: the feature moved to the Design stage! ![]()
We’ll keep you posted on the further progress ![]()
Quick update: the feature was moved to the development! ![]()
Friends, we’re happy to announce that the Google Analytics integration is already available in the widget ![]()
Check this post for more details - Spinning Wheel: Track user interactions with your widget using Google Analytics integration
