By default, breadcrumbs in Squarespace product page will be like this: Shop > Product Name
In this post, I will show you how to add Category Name between, so it will be: Shop > Category Name > Product Name, like this
Let’s start!
#1. First, you need to edit each product > Additional Info > Add a Code Block with this code
<div class="ProductItem-nav-breadcrumb custom-breadcrumb" data-animation-role="content">
<a href="/shop" class="ProductItem-nav-breadcrumb-link">Shop</a>
<span class="ProductItem-nav-breadcrumb-separator"></span>
<a href="/shop/gratuity" class="ProductItem-nav-breadcrumb-link">Gratuity</a>
<a href="/shop/p/custom-dress" class="ProductItem-nav-breadcrumb-link">Custom Dress — Deposit</a>
</div>
#2. Next, add this code to Settings > Developer Tools > Code Injection > Footer
$(document).ready(function(){
$('section.ProductItem-additional .code-block .ProductItem-nav-breadcrumb').appendTo('nav.ProductItem-nav');
<style>
nav.ProductItem-nav>div:not(.custom-breadcrumb) {
display: none !important;
</style>
#3. Repeat #1 for all products. DO NOT REPEAT #2
Note: You can edit Category Name/URL and Product Name/URL
Done.
If you any problems when installing this code, just comment below or send me a private message, I will help you.
Hello! Firstly, thank you so much for this custom breadcrumb code. I have been using it extensively on my site. Squarespace is now releasing V2 of their product pages and the CSS is changing. Here are their changes: Upcoming changes — Squarespace Developers
How should we update your code to remain functional through these changes?
Thank you.
@user26679 When your site done upgrade to V2, you can change.
In step #2, use this new code
$('section.ProductItem-additional .code-block .ProductItem-nav-breadcrumb').appendTo('nav.product-nav');
<style>
nav.product-nav>div:not(.custom-breadcrumb) {
</style>
and make sure you enabled this option.
If it still doesn’t work, you can share link to a product on your site, I will check again.
If you want a simpler, automatic way without having to insert Code Block into each Product, I also provide a solution, just insert the code once into Footer Injection, no need to edit the product, no need to do anything else, but it is paid code.
Ah, thank you! Your help set me on the right path. I had to enable Product Navigation > Breadcrumbs, otherwise Squarespace wouldn’t include the needed class=“product-nav” within the code.
However, this appended my custom breadcrumbs to appear after Squarespace’s generated breadcrumbs. I had to use the following code to find class=“product-nav” and replace it with my custom breadcrumbs instead of appending to it:
var $customBreadcrumb = $('section.ProductItem-additional .code-block .ProductItem-nav-breadcrumb');
if ($customBreadcrumb.length > 0) {
var $navContainer = $('nav.product-nav');
if ($navContainer.length > 0) {
$navContainer.html($customBreadcrumb);
The Squarespace generated breadcrumbs appear for a fraction of a second, but are replaced as soon as the footer code is loaded.
Example: Black Coffee Mug | Black Coffee Mugs for Metalheads
