Description: hover on top left of site will make all pages in navigation overlap as layered card
#1. Install Code
Note: code won’t apply on Link item or Dropdown
Use this code to Code Injection > Footer
- If you use Personal/Basic Plan and your plan doesn’t support Injection, see #3.1
<!-- 07.26c05v7 Layered card navigation -->
window.StackedPagesConfig = {
navSelector: ".header-display-desktop .header-nav-list .header-nav-item--collection > a",
triggerSelector: "",
trigger: {
width: 110,
height: 110
sheet: {
widthVW: 100,
heightVH: 100,
offsetX: 72,
offsetY: 64,
baseRotate: -4,
rotateStep: 1.5,
background: "#ECEAE3",
radius: 4,
iframeWidth: 1400
overlay: {
background: "rgba(12,12,12,0.92)",
zIndex: 99999
animation: {
duration: 1500,
stagger: 80,
easing: "cubic-bezier(0.22,1,0.36,1)"
preloadDelay: 500,
minWidth: 992
<script src="https://code.beaverhero.com/header/0726c05v7layeredcardnav.js"></script>
#2.1. To change overlay color, change Line 12
#2.2. All options you can find on Line 06 to Line 31
trigger: {
width: 110,
height: 110
sheet: {
widthVW: 100,
heightVH: 100,
offsetX: 72,
offsetY: 64,
baseRotate: -4,
rotateStep: 1.5,
radius: 4,
iframeWidth: 1400
overlay: {
zIndex: 99999
animation: {
duration: 1500,
stagger: 80,
preloadDelay: 500,
minWidth: 992
#3.1. If you use Personal/Basic Plan and your plan doesn’t support Injection, you can edit Site Footer
Add a Markdown Block
Add this code into Markdown Block
trigger: {
width: 110,
height: 110
sheet: {
widthVW: 100,
heightVH: 100,
offsetX: 72,
offsetY: 64,
baseRotate: -4,
rotateStep: 1.5,
radius: 4,
iframeWidth: 1400
overlay: {
zIndex: 99999
animation: {
duration: 1500,
stagger: 80,
preloadDelay: 500,
minWidth: 992
