(Squarespace) How to make Social Icons in lightbox on button click
To open Social Icons in lightbox on button click, like this
#2. Add Social Links Block then find IDs
#3. Edit button> Add link > Use this link format: #popup-hover=/popup-content#enter-social-links-block-id
For example #popup-hover=/popup-content#block-yui_3_17_2_1_1755072439738_26640
/* Popup style */
.popup-overlay {
    position: fixed;
    top: 0;
    left: 0;
    width: 100%;
    height: 100%;
    z-index: 9999;
    opacity: 0;
    visibility: hidden;
    transition: all 0.3s ease;
.popup-overlay.show {
    opacity: 1;
    visibility: visible;
.popup-modal {
    position: absolute;
    top: 50%;
    left: 50%;
    background: #fff;
    border-radius: 12px;
    max-width: 500px;
    max-height: 80vh;
    width: 90%;
    overflow: hidden;
.popup-modal:hover {
.popup-header {
    position: relative;
    padding: 20px 50px 20px 20px;
.popup-close {
    position: absolute;
    top: 15px;
    right: 15px;
    width: 30px;
    height: 30px;
    border: none;
    background: transparent;
    font-size: 18px;
    cursor: pointer;
    display: flex;
    align-items: center;
    justify-content: center;
    border-radius: 50%;
.popup-close:hover {
    background: #f0f0f0;
.popup-content {
    padding: 20px;
    max-height: 60vh;
    overflow-y: auto;
    line-height: 1.6;
.popup-loading {
    text-align: center;
    padding: 40px 20px;
    color: #666;
    font-style: italic;
.popup-error {
    text-align: center;
    padding: 40px 20px;
    color: #e74c3c;
    font-style: italic;
You can also use this Popup plugin instead, so you can do Social Icons popup on button click easier without using complex code.
