(Squarespace) Add a lightbox text when clicking a hyperlink text
To add a lightbox text when clicking a hyperlink text, like this.
You can follow these steps. But you can also use Popup plugin so you can achieve lightbox easier without using complex code.
#1. First, create a page with Name/URL: Popup Text – /popup-text
#2. Add 2 Text Blocks, then find IDs
#3. Edit the page containing hyperlink text you will click > Enter this URL format:
#popup-hover=/popup-text#enter-text-block-id
For example: #popup-hover=/popup-text#block-yui_3_17_2_1_1754201703787_13803
#popup-hover=/popup-text#block-674bceecc724c2e7fc82
/* Popup style */
.popup-overlay {
    position: fixed;
    top: 0;
    left: 0;
    width: 100%;
    height: 100%;
    z-index: 9999;
    opacity: 0;
    visibility: hidden;
    transition: all 0.3s ease;
.popup-overlay.show {
    opacity: 1;
    visibility: visible;
.popup-modal {
    position: absolute;
    top: 50%;
    left: 50%;
    background: #fff;
    border-radius: 12px;
    max-width: 500px;
    max-height: 80vh;
    width: 90%;
    overflow: hidden;
.popup-modal:hover {
.popup-header {
    position: relative;
    padding: 20px 50px 20px 20px;
.popup-close {
    position: absolute;
    top: 15px;
    right: 15px;
    width: 30px;
    height: 30px;
    border: none;
    background: transparent;
    font-size: 18px;
    cursor: pointer;
    display: flex;
    align-items: center;
    justify-content: center;
    border-radius: 50%;
.popup-close:hover {
    background: #f0f0f0;
.popup-content {
    padding: 20px;
    max-height: 60vh;
    overflow-y: auto;
    line-height: 1.6;
.popup-loading {
    text-align: center;
    padding: 40px 20px;
    color: #666;
    font-style: italic;
.popup-error {
    text-align: center;
    padding: 40px 20px;
    color: #e74c3c;
    font-style: italic;
you can consider use this Popup plugin instead, so you won’t need to use complex code to add lightbox text.
<script>document.addEventListener('DOMContentLoaded',function(){const CONFIG={popupPageUrl:'/popup-text'};let popupOverlay=null;function createPopup(){const overlay=document.createElement('div');overlay.className='popup-overlay';const modal=document.createElement('div');modal.className='popup-modal';const header=document.createElement('div');header.className='popup-header';const closeBtn=document.createElement('button');closeBtn.className='popup-close';closeBtn.innerHTML='×';closeBtn.addEventListener('click',hidePopup);const content=document.createElement('div');content.className='popup-content';header.appendChild(closeBtn);modal.appendChild(header);modal.appendChild(content);overlay.appendChild(modal);document.body.appendChild(overlay);overlay.addEventListener('click',function(e){if(e.target===overlay){hidePopup()}});return overlay}
function showPopup(content){if(!popupOverlay){popupOverlay=createPopup()}
const contentDiv=popupOverlay.querySelector('.popup-content');contentDiv.innerHTML=content;popupOverlay.classList.add('show');document.body.style.overflow='hidden'}
try{const response=await fetch(CONFIG.popupPageUrl);if(!response.ok)throw new Error(`HTTP ${response.status}`);const html=await response.text();const parser=new DOMParser();const doc=parser.parseFromString(html,'text/html');const targetElement=doc.querySelector(blockId);if(targetElement){const content=targetElement.innerHTML.trim()||'No content found';cache.set(cacheKey,content);return content}else{throw new Error('Block not found')}}catch(error){console.error('Fetch failed:',error);throw error}}
