I’m looking to inclde a slideshow on my website
Hi there, @Arnie_Dunn and welcome to the Community ![]()
Could you please describe your use case in more detail? What content would you like to display in your slideshow? Would you like to manually switch slides or should they change automatically?
Any additional info would be much appreciated ![]()
Hi Max
I was hoping for a simple slideshow of images. The images can be manipulated to be the correct Mb size. but simple timed changes like powerpoint.
Got it, thanks!
I think our Photo Gallery app must be a tool you’re looking for.
Here you can change Slider or Carousel layout and enable the Autoplay feature to automatically slide photos.
Additionally, you can click on the image and enable the Slideshow mode. Here is a video screencast showing how it works:
Give it a shot and let me know if it covers your needs ![]()
Many thanks for this, I’m finding my way!
With Kind Regards
Arnie Dunn
It’s my pleasure ![]()
