Slider widget stopped loading on a webpage.
Was working fine yesterday, today does not load.
Other widget from elfsight works fine.
Sorry about the interruption in our widget’s performance!
The issue is fixed. Check it out and let me know if it’s fine ![]()
Fixed,thanks
czw., 7 gru 2023, 16:06 użytkownik Max via Elfsight Community <notifications@elfsight.discoursemail.com> napisał:
You are always welcome ![]()
