Single script custom code widgets (hosting GPT/Claude created artifacts)
Hi, I’d like some more customizability which I can get by using GPT prototyping / Claude artifacts to create more personalized widgets. Since I host all my website’s widgets through Elfsight it would only make sense if I can host the custom widgets here as well. I don’t expect support on creation, more a use at your own risk type of thing. I would need the ability to make external api calls. Hope you guys can make this work!
I understand there are other ways I can host the custom widget but I value having everything in the same place highly.
Example of vibe coded prototype: ChatGPT - Boekhoudkeuzehulp – Interactieve Widget (prototype)
Best,
Maarten
Hi there and welcome to the Community, @ZZP_Nederland :waving_hand:
Do I get it right that you’re looking for a section where you could add widget codes generated by AI and add them to the website as Elfsight widgets?
