Showing more than 3 FB posts
I have this Facebook feed set to show three posts, but it appears to be showing a whole lot more than that. Can you help?
https://dash.elfsight.com/widget/e4b79d9a-8cd6-47aa-ad3a-7c54238957f7
Greetings @Hugh :wave:
The issue is fixed and everything should be back to normal. Please check your widget and let me know if it’s fine now :slightly_smiling_face:
Yes, good now.
