A quick and easy way to show files from a specific Sharepoint folder on a web page.
Hi there, @Yngve1 ![]()
Could you please describe which files (file formats) you’d like to show in the widget? Also, do you have an example of the link to your Sharepoint file. I’ll gladly check with the devs if it works in our File Embed app ![]()
