Set sharing URLs for tables
My setup: a website with your pricing table embedded.
Goal: Create external links that directly open specific tabs instead of always opening the first tab.
I’m using your Pricing Table widget with 4 tabs
Issue:
All tabs currently share the same URL, but I need separate external links for each tab so I can direct users from emails/social media to specific tabs.
It would be great if the “Multiple Tables Mode” feature could enable the tab-specific URLs or deep linking
Or I could create direct links like mysite.com/pricing?tab=payment that automatically open the Payment tab
Hi there, @Kyoto_International and welcome to the Community :waving_hand:
Thanks for the idea! We’ll try to think about it as an option in the settings, especially if more users upvote this idea :slightly_smiling_face:
I also see that my colleague Oksana has shared a custom solution for your case in a support ticket.
Just in case you want the tab parameters to be automatically added to the page, we’ve also got a solution. Please check it out :wink: - How to get a link to a specific table in Multiple Tables mode
Hi @Max
Expanded a bit, this would be a good post for Pro Tips.
Or is the one from the portfolio also suitable? I haven’t tested it.
https://community.elfsight.com/t/portfolio-how-to-get-a-link-to-a-certain-category/110925
Well noted, thanks :slightly_smiling_face:
The first solution was case specific, so I’ve removed it from the thread to avoid any confusion.
And the 2nd workaround was added to the Pro Tips section - How to get a link to a specific table in Multiple Tables mode
The code for the Portfolio widget won’t work for the Pricing Table.
