Set schedule for widget display
that would help a lot with time and schedules.
Hi there, @Tayeb :wave:
Great idea, thanks for sharing! Let’s see if it catches on with the community :slightly_smiling_face:
Although this feature isn’t available in the settings, it’s possible to create a custom code for this case.
Could you just send me a link to the page where your widget is installed?
sorry max, thanks for getting back to me, the widget is not installed at the moment but the idea is to let the users listen to our free radio station and then move them on to check out our other services and that is possible with this widget. Then I thought I could put it on a schedule that would let them listen for free during our prime time hours by turning off the widget from 7 - 11 at night.
anyways, if i use the countdown timer tool at a later date as it could help to have a schedule setting just to make it more professional and customizable.
i think it’s one of the best widgets
my website is elte.co.uk
i would appreciate your feedback on the website and how you think its getting on
cheers mate,
elte
Hi @Tayeb :wave:
Could you please specify the timezone where the widget shouldn’t be displayed from 7 to 11 p.m?
GMT - London time
Thank you! And the last question, I see that you have 3 Countdown Timers. Could you please specify the name of the timer where you’d like to implement this schedule?
Hey everyone!
We’re happy to announce that now you can choose the start and end date for the timer. Once the time is over, the widget will disappear from the page:
Guys, currently, this feature is available only in the widgets created after this release. However, the good news is that we can manually update your existing widgets on our end :slightly_smiling_face:
Check this post for more details - Countdown Timer: [MAJOR UPDATE] Auto-repeat option, layout enhancements, new buttons, themes and more! 🔥
