Scrolling Marquee Bar
I think a scrolling marquee bar would be a great app to add for it to help with peoples sales and getting announcements out. Making it scrolling would m it’s eye catching. There are other apps out there that does this but I rather have all my apps from the same developer.
Hi there, @Tina_Luthro and welcome to the Community :waving_hand:
Do I get it right that all elements (badge, text and button) should be scrolling?
Could you please specify the direction of the animation (right to left or left to right)? I’ll be happy to check with the devs if anything can be done :slightly_smiling_face:
Yes and be able to place anywhere. Not have it pinned to the top, bottom or hover.
You can change the position of the bar using the available position options in the settings:
Could you just specify the direction of the animation you’d like to have (right to left or left to right)?
