Script to control time display
I need to disable display of event end time, and show start time only. I see that custom code can be used in the widget. Is there a CSS or JS solution to accomplish this?
Hi Chris, and welcome to the forum. The Staff does know its CSS, so they should be able to help you. Hang in there, Staff will be with you when they return from their well-deserved weekend.
Thanks, Mike, looking forward to it. :o)
Greetings @Chris_Malta and welcome aboard :wave:
To hide the end time, you just need to set the same start and end tine of the event:
Could you please check it and let me know if it helped :slightly_smiling_face:
It did. Excellent. Thanks Max.
Great!
You are most welcome :wink:
