Sales Notification customization
Hey Max!
Wondering if you can send me the custom css for adding more padding to the sales notification widget? It maxs out at 40 - would like to add more when needed.
Shawn Martin
FanYourLocal
Sure, could you please send me a link to the webpage where your widget is installed or specify widget id?
Sure!
Thank you.
Shawn Martin
FanYourLocal
Here is the code you should add to the Custom CSS field on the Style tab:
[class*="widget__Container-sc"]{
  padding: 20px 30px;
Please check it and let me know if it helped :slightly_smiling_face:
