Hey Max,
Looking for a bit more offset for the Sales Notification widget…could you send me the CSS to adjust positioning for vertical & horizontal please?!
Thank you,
Shawn
Hey Max,
Thank you,
Shawn
Hi there, @Shawn_Martin1 ![]()
You can do this in the Position section on the Layout tab:
If you’d like the offsets to be more than 40 px, you can just manually type the needed value there.
