Our devs have rolled out a batch of fixes for our Reviews apps ![]()
AI Summary
- Adjusted padding of the Author Block in the Spotlight card.
- Added missing translations for AI Summary text.
- Fixed an issue where AI Summary wouldn’t appear when source grouping was enabled for a specific source type.
Layout & Design
- Standardized header spacing in the Pane Badge layout to match the Feed layout.
- Corrected mobile resizing for the Compact Badge.
- Resolved layout issues in Carousel when using RTL mode.
Badges
- Fixed a bug where clicking a custom source badge opened the “All” tab instead.
- Removed unwanted badge flickering when changing non-width settings.
- Fixed the “Review Verified” tooltip not showing on hover in the Pane Badge layout.
