Request for Gzip/Brotli Compression on allInOneReviews.js
Dear Elfsight Support Team,
I hope you’re doing well.
We are currently using the All-in-One Reviews widget on our website and have noticed that the JavaScript file served from your CDN:
arduino
KopyalaDüzenle
https://universe-static.elfsightcdn.com/widget/allInOneReviews.js
is being delivered without compression (gzip or Brotli). As a result, the file size exceeds 1 MB and is significantly impacting our website’s performance scores, especially in Google PageSpeed Insights (triggering the “Enable text compression” warning).
Could you please enable gzip or Brotli compression on this file?
This would greatly help us improve our LCP and overall Core Web Vitals performance.
Looking forward to your response, and thank you for the great widget!
Best regards,
Hakan - lingusta.com.tr
Hi there and welcome to the Community, @Lingusta_Egitim :waving_hand:
I’ve checked your website using the Google PageSpeed Insights and don’t see a warning “Enable Text Compression”. Could you please send me a screenshot of the error you see?
