Remove watermark
I have subscribed to elfsight platform in Pro package for all applications. But when I link the applications on my site, the elfsight watermark appears. Can anyone help me solve the problem and remove it?
Hi @user19926 welcome to community :clap:
I think you mean the Information Panel.
Please don’t worry, this is not a bug, but a helpful feature called the information board. Rest assured that this panel is only visible to you when you are logged into your Elfsight account and your website visitors cannot see it at all.
In case you don’t want to see the panel, you can hide it by adding this CSS code to the Custom CSS section of your widget
  display: none !important;
Hi there, @user19926 :wave:
Sina is absolutely right! This is the informational panel that is visible only to you as the account owner when you’re logged in to Elfsight.
If you don’t want to see this panel. please use the CSS code suggested by Sina :wink:
