Remove paddings on mobile
Hi Max, this only seems to work if you want to add more padding. I want to remove padding but it does not respond to negative padding. The margins are too wide but I cannot seem to adjust those. Do you have a code for that?
tnx. Jeroen
Hi there, @Jeroen_Jonkman :waving_hand:
Just to clarify, would you like to reduce the spacing between event cards (1) or you’d like to remove side and bottom spacing in the event cards (2)?
Hi Max, neither. I want the entire card to be closer to the edge of the screen (on both sides). See attached for clarification.
Got it, thanks!
Please try to use this CSS code and let me know how it worked:
@media(max-width: 600px) {
  [class*="WidgetBackground__Wrapper-sc"] {
    padding-left: 0 !important;
    padding-right: 0 !important;
  .global-styles,
  .fusion-fullwidth:has(.eapp-events-calendar-events-calendar-component) {
works like a charm. Thanks so much Max. Appreciate it.
Great, you’re always welcome!
By the way, we’d like to invite you to participate in our Birthday Contest, where you can win a 12-month extension for your subscription - Birthday Contest: 10 Winners, 10 Free Years with Elfsight! :wrapped_gift:
