Remove padding in Logo Showcase
If you could share a direct link to the page with the widget, I would be happy to check things for you :slightly_smiling_face:
Link to see about removing lines in Headings
Pizza Flame - Dine-in, take-out & delivery. Banquet Room Available.
fanyourlocal.com
favicon.ico
](Pizza Flame - Dine-in, take-out & delivery. Banquet Room Available. — FanYourLocal)
Shawn Martin
FanYourLocal
Your request is now with our devs. I’ll keep you in the loop here :slightly_smiling_face:
Thank you! Also, having issues with Facebook widget. Button sizing seems off, can’t ask for feature request as it goes to an error page.
Shawn Martin
FanYourLocal
Unfortunately, our service encountered some technical issues, that’s why you can’t request feature at the moments.
You can follow the updates in this thread.
Do I understand correctly, that you’d like to change the size of the Chat Bubble in your Facebook Chat widget?
No the “start a chat” button shows full width when setting up widget but when live on site shows small button aligned to the left. You can see in your screenshot.
Shawn Martin
FanYourLocal
Got you!
We’ll check this issue as well :slightly_smiling_face:
Hey @Shawn_Martin :wave:
We’ve fixed the Start chat button with the help of this code:
.global-styles,
[class*="eapps-facebook-chat"] [class*="ButtonBase__ButtonContainer"] {
  width: calc(100% - 40px);
As for the dashes in Restaurant Menu, please use this CSS code:
.global-styles,
[class*="eapps-restaurant-menu"]
[class*="Info__InfoTitle"]::before,
[class*="Info__InfoTitle"]::after {
  display: none;
Hi,
The View Profile —> link not showing up on content that I add external link to. Only content that I add info to bio. This is something new and wondering if can be fixed?
Shawn Martin
FanYourLocal
Hi @Shawn_Martin
Could you please share a link to the page where the widget is installed?
If you see the Pizza Flame container doesn’t show a See Profile
Discover Coon Rapids MN through a trusted resource for local business information.
fanyourlocal.com
favicon.ico
](Discover Coon Rapids MN through a trusted resource for local business information. — FanYourLocal)
But if you look at the link below
Tap pizza you’ll see Chanticlear Pizza does all I am doing is adding an external link to go to a webpage.
Shawn Martin
FanYourLocal
Hi @Shawn_Martin :wave:
View profile button isn’t displayed because Biography field is empty. If you add some info, the button will be displayed :slightly_smiling_face:
Do you have css to remove or lessen the rounded corners on Google Review widget containers?
Thank you,
Shawn Martin
FanYourLocal
651-707-5530
You can do this right in the configurator. Just click on the Review section on the Appearance tab and set Radius:
Sorry didn’t see that.
Thank you.
Shawn Martin
FanYourLocal
651-707-5530
You are always welcome :slightly_smiling_face:
Hey Max,
I would like to add some easing to a back to top button using your custom js functionality. How would I go about finding the html element id to do so?
Thank you,
Shawn Martin
FanYourLocal
Could you please describe your use case in more detail and share a link to the webpage where your widget is installed?
Hi,
It seems that when inputting hours into the “Special Hours” area within the widget it’s a day behind. So if I do Veterans Day for Nov 10 it shows it’s Nov 9 in the content area? So I have to make it a day ahead (Nov 11) in order for it to display the day I am looking to provide special hours for.
Also, any update on making Open 24 Hours as an option?
Shawn Martin
FanYourLocal
Unfortunately, we don’t have any updates on Open 24 hours option, I am sorry!
All the news will be posted in this thread - Add an option to be open 24 hours.
As for the Special Days issue, could you please send me a direct link to the page with the widget?
I’ll be happy to investigate it for you :slightly_smiling_face:
