Logo Showcase padding adjustment
I need to reduce the padding of the outer background container, as well as the internal container that contains the logo.
Hi there, @David_Crockett :wave:
You can reduce the inner padding using the Vertical Padding setting in the Background section on the Style tab of your widget’s settings:
And what do you mean under the outer padding? Could you please send me a screenshot?
Ok that took care of the bigger issue, thank you! Is it possible to reduce this padding…
Screenshot 2024-12-06 123752|690x258
Also, is it possible to add to top of a page similar to what you can do with the count down timer?
I’ve forwarded your Logo Showcase request to the devs and will get back to you on Monday :slightly_smiling_face:
As for the 2nd idea, I am afraid, I didn’t quite understand it. Could you please elaborate on what you mean?
Hi @David_Crockett :wave:
We’ve removed paddings by adding this code to the Custom CSS field on the Style tab of your widget’s settings:
.es-layout-carousel-wrapper {
  height: 54px;
Check it out and let me know if it’s fine now :slightly_smiling_face:
Perfect!!! Thanks
No sweat :wink:
In the meantime, we’d like to remind about our Black Friday Giveaway, where you can win 1 FREE YEAR for any of your subscriptions :gift:
Check the details and join in - BF 2024 Giveaway: Win 1 YEAR of Free Usage (10 Winners) + guaranteed month!
