Remove infinite scrolling for Slider layout
Hi there @user10382 :wave:
Do I understand correctly that you’d like to display only the left arrow when reaching the last post in your widget?
Yes, that’s it!
A way of disable infinite loop basically
Got you!
I’ve shared your request with the devs and will let you know if anything can be done :slightly_smiling_face:
Thank you so much!
I’ve talked to the devs and, unfortunately, it’s impossible to customize the widget this way at the moment. I am so sorry :pensive:
I’ve added your idea to the Wishlist and we’ll try to consider this feature in our upcoming updates. We’ll keep you posted in this thread!
Right, thank you!
