Awe, that is very sweet of you, thanks!
Where do I get the IDs? If it helps, my source is: @chantellroberts.co.
I would really like this removed, I’ve changed my branding and it does NOT fit:
Hi @user30518, welcome to the Community ![]()
I’ll be glad to help you get rid of the removed post! To get your widget ID:
Let’s get it solved together ![]()
