Questions about Elfsight plans
Hi all — I’m evaluating Elfsight for a use case that may be outside the usual scope and want to check feasibility before committing.
We manage a directory-style setup with around 500 client profile pages, and we’d like to display live Instagram and Facebook follower counts on each profile — roughly 300 unique social accounts in total across the set. Each counter would need to be pointed at a different client’s Instagram/Facebook account, so we’re looking at 300+ distinct widget instances rather than one widget reused across pages.
A few specific questions:
  1. Does a single Elfsight account support creating this many individual widget instances, or is there a per-account cap?
  2. How does pricing scale at this volume — is it per-widget, per-view, or bundled under a higher-tier plan?
  3. Is there any bulk setup or API-based provisioning, or does each widget need to be configured manually through the dashboard?
  4. Are there view/impression limits per widget or per account that would be a concern at this scale?
Appreciate any pointers from anyone who’s run Elfsight at similar volume, or from the Elfsight team directly if you’re watching.
Thanks.
Hi there, @Sam_Hogg and welcome to the Community :waving_hand:
Sure, I’ll be happy to advise!
  1. Yes, is’t possible to create 300+widgets in a single Elfsight account.
  2. The most suitable plan for your case would be Enterprise T4. It has no view limit and allows you to create up to 400 widgets. For example, if you choose the Social Feed Enterprise T4 plan, you’ll be able to create up to 400 Social Feed widgets:
  1. At the moment, bulk setup and API-based provisioning aren’t available. However, if your widgets will have the same or similar settings, you can simply duplicate them and then adjust them as needed:
If you have any other questions about our Enterprise plans, feel free to contact us at enterprise@elfsight.com. Our Enterprise manager will be happy to help :wink:
