Question and Answer position with Categoires
Can we align the questions (e.g., “Can I cancel my subscription at anytime?”) with the category titles (e.g., “All Questions”) so that they start at the same left position?
Right now, the category headers are aligned further left than the questions below them. I’d like the Q&A text (summary line) to visually line up with the heading text for consistency.
Hi there, @David_Drew :waving_hand:
Yep, this code will do the trick:
.eapps-faq-content-category-title-text {
  padding-left: 37px;
Please add it to the Custom CSS field on the Appearance tab of your widget’s settings and let me know if it helped :wink:
Fantastic, thank you. Could we have the code in reverse (so to speak), so that the questions are pulled to the left to line up with the category title that way? So everything is aligned to the left?
Thanks,.
David.
Hi @David_Drew
should it be like this?
.eapps-faq-content-category-item-question-text{
  padding-left: 17px;
The Sina’s code should work for your case. However, if it doesn’t work the way need, please describe your idea in more detail :slightly_smiling_face:
