QR Code with a Dead Link
Hi,
The QR code that I have printed on my business cards lead to a dead link. And I no longer have the QR code in my account, so I can’t update the link. Is there a way to insert the QR code so that I can edit it?
Thank you,
Tanya
Hi there, @Tanya_Cienfuegos-Bac :wave:
Do I get it right that you’ve removed the QR code widget with the dead link from your account?
If it is, do you remember the name of this widget/date when it was deleted? If no, could you please send me the URL of this dead link?
I’ll try to find the deleted widget and restore it, so that you could change the link :slightly_smiling_face:
That is correct. Here is the dead link: https://www.tanyashairbows.com/store/p396/Cotton_Candy_.html
Thank you,
Tanya
I’ve checked all widgets in your account (deleted and existing) and there are no QR codes using this link.
If you have the QR code with this link installed on the website, please share the link to the page with it. I’ll gladly look into this for you :slightly_smiling_face:
However, if this QR code is available only in printed cards, I am afraid there is no option to change the link. The only solution is to create a new QR Code widget with the relevant link.
I really appreciate you looking into this. Thank you!
No sweat!
If anything else comes up, we’ll be delighted to help :wink:
