For the forms builder and perhaps with other widgets, it would be great if a QR code was generate as way to print it offline; whereby it can be scanned and point the the form (or other widgets as appropriate). This would be a HUGE improvement ![]()
Hi there, @user27412 ![]()
Basically, you can share all widget except Forms with QR code. For this, you’ll need to select a URL type of QR code and a widget Share Link there:
The Form widget used to have the Share Link option, but we had to deprecate it, since it was used for the fraudalent actions. We already have a request to restore the Share Link feature for Forms and you can upvote it here
- How to Share Widget via Link - Elfsight Help Center
