Push Spinning Wheel data to Zapier via webhook
If this is taking longer to implement, is it possible to have a Java Script template that pushes the data to Zapier’s web hook trigger instead? This could be a quicker, short term solution for this.
Thanks!
Welcome to the Community, @user26066 :waving_hand:
I’ve discussed this with the devs and it is technically possible. However, please note that since the webhook would be public, there’s a slight risk that some users could send fake requests and results, even without actually using the wheel.
If you’re okay with this limitation, our developers can work on a custom solution for you. Let us know if you’d like to proceed :slightly_smiling_face:
How is the web hook public.
Sorry for being not clear enough!
What I meant is that you can see the requests being sent to the webhook by checking the website through DevTools. However, regular users (without a tech background) won’t see this :slightly_smiling_face:
Ya, im not worried about that. How can I set it up?
Great! Our devs will create a custom solution for you.
I’ve passed your request to them and will update you once it’s done :slightly_smiling_face:
Hi there, @Smash_N_Dash_Rage_Ro :waving_hand:
Here is a solution from our devs:
const webhookUrl = "";
const widgetId = "4a70fb23-caff-45e1-99bc-b568274235e3";
const data = {
  email: "",
  promocode: "",
const sendToWebhook = (data) => {
  const formData = new FormData();
  for (const key in data) {
    formData.append(key, data[key]);
  fetch(webhookUrl, {
    method: "POST",
    body: formData,
const selectPortal = () =>
  document.querySelector(`.es-portal-root[class*='${widgetId}']`);
const selectForm = (portal) => portal.querySelector("[class*='Form']");
const selectPromoCode = (portal) =>
  portal.querySelector("[class*='Coupon__Value']")?.textContent || "";
const selectEmailInput = (form) => form.querySelector("[type='email']");
const observePortal = (portal) => {
  const portalObserver = new MutationObserver(() => {
    const form = selectForm(portal);
    if (form) return;
    const promocode = selectPromoCode(portal);
    if (!promocode || !data.email) return;
    data.promocode = promocode;
    sendToWebhook(data);
    portalObserver.disconnect();
  portalObserver.observe(portal, { childList: true, subtree: true });
const handleData = (portal) => {
  if (!form) return;
  const input = selectEmailInput(form);
  if (input && input.value && input.checkValidity()) {
    data.email = input.value;
const watchPortal = () => {
  const documentObserver = new MutationObserver(() => {
    const portal = selectPortal();
    if (!portal) return;
    observePortal(portal);
    documentObserver.disconnect();
    portal.addEventListener("keydown", (event) => {
      if (event.key === "Enter") handleData(portal);
    portal.addEventListener("click", () => {
      handleData(portal);
  documentObserver.observe(document, { childList: true, subtree: true });
watchPortal();
Add your webhook in the 1st line of the code and add the resulted code to the Custom JS field on the Settings tab of your widget’s settings:
