Max, can you adjsut the code to make the property filed uneditable or read only the link address is copied to the field
Hi there, @backhome84
Your request is with our devs now. I’ll get back to you once I have their response
Thank you for waiting, @backhome84!
Our devs adjusted the code and the property links are uneditable now. Please check your website and let me know if everything is fine
Yes it is fine. Thank you
Can we also make that field grayed out?
Okay, I’ve asked the devs to adjust the code.
I’ll report back once the solution is ready
Done! Please check your widget and let me know if you like the result
Thank you so much
