Problems with custom CSS
Navigation arrows not showing inside circles and video popup not scaling
Despite this:
  • The blue circles for the navigation buttons appear, but the white arrows (::after) don’t render.
  • Videos in the popup still sit in the top-left corner instead of filling/centering within the popup.
Could you advise how to properly target the navigation icons and how to get videos to scale correctly in the popup?
Thanks!
:root {
–nf-h: 500px;
/\* Media wrapper fixed height */
.eapps-social-feed-post-picture,
.eapps-social-feed-post-picture-inner,
.eapps-social-feed-post-picture-image,
\[class*=“MediaContainer”\],
\[class\*=“PostMedia”\] {
height: var(–nf-h) !important;
display: flex !important;
align-items: center !important;
justify-content: center !important;
overflow: hidden !important;
/\* Contain images/videos */
.eapps-social-feed-post-picture img,
.eapps-social-feed-post-picture video,
\[class*=“MediaContainer”\] img,
\[class\*=“MediaContainer”\] video {
max-width: 100% !important;
max-height: 100% !important;
object-fit: contain !important;
margin: 0 auto !important;
/\* Popup videos \*/
.eapps-social-feed-post-popup video {
max-height: 80vh !important;
/\* Popup arrows \*/
.eapps-social-feed-post-popup .swiper-button-next,
.eapps-social-feed-post-popup .swiper-button-prev {
width: 50px !important;
height: 50px !important;
border-radius: 50% !important;
background: #256bc6 !important;
color: #fff !important;
top: 50% !important;
transform: translateY(-50%) !important;
background-image: none !important;
/\* White triangle arrow shapes \*/
.eapps-social-feed-post-popup .swiper-button-next::after {
content: “” !important;
border-top: 8px solid transparent;
border-bottom: 8px solid transparent;
border-left: 12px solid #fff;
.eapps-social-feed-post-popup .swiper-button-prev::after {
border-right: 12px solid #fff;
Hi there, @Novoferm :waving_hand:
The issue with the video alignment appeared because of these line in the code:
And the arrow icons didn’t appear because you’ve used [class*="ArrowControl"] and I’ve replaced it with the more precise [class*="ArrowControl__ArrowControlContainer-sc"] here:
Please check your widget and let me know if it’s fine now :slightly_smiling_face:
Hi Max, I see that this is indeed working. There’s just one more thing that isn’t functioning properly: the video elements in the popup window. I’d like them to span the full width of the left column. How can I adjust this?
It’s possible, but the video will get cropped in this case. Would you like to proceed with this solution?
Hi Max, Maybe we should keep it only in full width? It’s no problem if the video doesn’t completely fill the column, but I think it will look better that way.
Okay, I’ll ask the devs to provide a solution for this and will let you know once I have any news :slightly_smiling_face:
Here is a final solution from our devs:
/* ===== FEED: 500px hoog, afbeelding volledig (contain) ===== */
:root {
  --nf-h: 500px;
.hjxXsz .swiper {
  max-width: 90%;
[class*="Popup__PopupContent-sc"] [class*="Columns-sc"]>div:not(:has(video)) {
  display: flex;
  flex-direction: column;
  flex: 1 1 29%;
/* kaart mag buitenranden tonen (voor pijlen) */
.eapps-social-feed-post,
[class*="Post"],
[class*="Card"],
[class*="GridItem"],
[class*="Feed__Item"] {
  overflow: visible !important;
/* media-wrapper op vaste hoogte + centreren met flex */
[class*="MediaContainer"]:not(:has(video)),
[class*="PostMedia"] {
  padding-top: 0 !important;
  height: var(--nf-h) !important;
  min-height: var(--nf-h) !important;
  position: relative !important;
/* <img>/<video>: nooit croppen, schaal binnen 500px */
.eapps-social-feed-post-picture picture img,
[class*="MediaContainer"] img,
/* [class*="MediaContainer"] video, */
[class*="PostMedia"] img,
[class*="PostMedia"] video {
  position: static !important;
  width: auto !important;
  height: auto !important;
  object-position: center center !important;
  display: block !important;
/* background-image varianten */
.eapps-social-feed-post-picture[style*="background"],
.eapps-social-feed-post-picture-inner[style*="background"],
.eapps-social-feed-post-picture-image[style*="background"],
[class*="MediaContainer"][style*="background"],
[class*="PostMedia"][style*="background"] {
  background-size: contain !important;
  background-position: center !important;
  background-repeat: no-repeat !important;
/* inline fixes */
[style*="object-fit: cover"] {
[style*="background-size: cover"] {
[style*="padding-top"] {
/* swiper/slides volgen onze 500px */
.eapps-social-feed-post .swiper,
.eapps-social-feed-post .swiper-wrapper,
.eapps-social-feed-post .swiper-slide,
[class*="Carousel__CarouselSwiper"] {
/* ===== FEED: Swiper-pijlen volledig uit ===== */
.eapps-social-feed-post [class*="swiper-button"] {
  display: none !important;
  pointer-events: none !important;
  opacity: 0 !important;
/* ===== ELFSIGHT BOLLEN: bol + pijltje als één geheel ===== */
/* verberg eventuele SVG's van Elfsight */
[class*="CarouselArrowControlContainer"] svg,
[class*="ArrowControl__ArrowControlContainer-sc"] svg {
  display: n !important;
/* bol basis */
[class*="CarouselArrowControlContainer"] button,
[class*="ArrowControl__ArrowControlContainer-sc"] button {
  align-items: center;
  justify-content: center;
  /* blauwe bol */
  cursor: pointer;
/* DEBUG: rechts */
[class*="CarouselArrowControlContainer"][class*="Right"] button::after,
[class*="ArrowControl__ArrowControlContainer-sc"][class*="Right"] button::after {
  content: "R" !important;
  /* tijdelijk */
  position: absolute !important;
  left: 50% !important;
  transform: translate(-50%, -50%) !important;
  width: 14px;
  height: 14px;
  background: red !important;
  color: white !important;
  font-size: 10px;
  text-align: center;
  line-height: 14px;
  z-index: 9999 !important;
/* DEBUG: links */
[class*="CarouselArrowControlContainer"][class*="Left"] button::after,
[class*="ArrowControl__ArrowControlContainer-sc"][class*="Left"] button::after {
  content: "L" !important;
  /* tijdelijk */
  width: 14px;
  height: 14px;
  font-size: 10px;
  text-align: center;
  line-height: 14px;
/* positie van de bollen */
[class*="CarouselArrowControlContainer"][class*="Left"],
[class*="ArrowControl__ArrowControlContainer-sc"][class*="Left"] {
  left: -26px !important;
[class*="CarouselArrowControlContainer"][class*="Right"],
[class*="ArrowControl__ArrowControlContainer-sc"][class*="Right"] {
  right: -26px !important;
[class*="CarouselArrowControlContainer"],
[class*="ArrowControl__ArrowControlContainer-sc"] {
  top: 160px !important;
  transform: none !important;
  z-index: 10 !important;
/* mobiel: iets naar binnen */
@media (max-width: 640px) {
    left: 8px !important;
    right: 8px !important;
/* ===== POPUP: afbeeldingen contain + swiper pijlen gecentreerd ===== */
.eapps-social-feed-post-popup .eapps-social-feed-post-picture,
.eapps-social-feed-post-popup .eapps-social-feed-post-picture-inner,
.eapps-social-feed-post-popup .eapps-social-feed-post-picture-image {
  min-height: 0 !important;
.eapps-social-feed-post-popup .eapps-social-feed-post-picture img,
.eapps-social-feed-post-popup .eapps-social-feed-post-picture picture img,
.eapps-social-feed-post-popup .eapps-social-feed-post-picture video,
.eapps-social-feed-post-popup .eapps-social-feed-post-picture-image img,
.eapps-social-feed-post-popup .eapps-social-feed-post-picture-image video {
  width: 40px;
  height: 40px;
  border-radius: 50%;
  background: rgba(0, 0, 0, 0.4);
  color: #fff;
/***** 1) PROBE: laat zien of we de knoppen raken *****/
  outline: 3px solid fuchsia !important;
  /* PROBE */
.eapps-social-feed-post .swiper-button-next,
.eapps-social-feed-post .swiper-button-prev {
  outline: 3px dashed lime !important;
  /* PROBE */
/***** 2) ZET SWIPER-PIJLEN WEER AAN (we override de hide-regel) *****/
  pointer-events: auto !important;
  opacity: 1 !important;
/* ZEKER WETEN: verwijder eventuele iconen/achtergronden van Swiper */
  /* blauwe bol */
  /* gelijk aan jouw custom positie */
  z-index: 20 !important;
  /* haal eventuele default icons weg */
  box-shadow: none !important;
/* posities links/rechts */
.eapps-social-feed-post .swiper-button-next {
/* mobiel iets naar binnen */
/***** 3) BORDER-TRIANGLE PIJLEN OP DE SWIPER-KNOPPEN *****/
/* Rechts (›) */
.eapps-social-feed-post .swiper-button-next::after {
  content: "" !important;
  transform: translate(-40%, -50%) !important;
  /* iets naar rechts in de bol */
  width: 0;
  height: 0;
/* Links (‹) */
.eapps-social-feed-post .swiper-button-prev::after {
  transform: translate(-60%, -50%) !important;
  /* iets naar links in de bol */
  width: 0;
  height: 0;
/* Hover (optioneel, netter gevoel) */
.eapps-social-feed-post .swiper-button-next:hover,
.eapps-social-feed-post .swiper-button-prev:hover {
  filter: brightness(1.08) !important;
/* ===== POPUP: media netjes 'contain' + gecentreerd ===== */
.eapps-social-feed-post-popup .eapps-social-feed-post-picture-image,
.eapps-social-feed-post-popup [class*="MediaContainer"],
.eapps-social-feed-post-popup [class*="PostMedia"] {
  background: #000;
  /* optioneel: zwarte balken */
/* <video> binnen popup: volledige video zichtbaar */
/* iframes (YouTube/Vimeo/LinkedIn) ook 'contain' */
.eapps-social-feed-post-popup iframe {
  border: 0 !important;
  aspect-ratio: 16 / 9;
  width: min(100%, calc(80vh * (16 / 9))) !important;
/* inline styles van bronnen forceren naar contain */
.eapps-social-feed-post-popup [style*="object-fit: cover"] {
.eapps-social-feed-post-popup [style*="background-size: cover"] {
.eapps-social-feed-post-popup [style*="padding-top"] {
/* Swiper in popup: laat de slides zich centreren en niet forceren op vaste hoogte */
.eapps-social-feed-post-popup .swiper,
.eapps-social-feed-post-popup .swiper-wrapper,
.eapps-social-feed-post-popup .swiper-slide {
/* Pijlen in popup: midden op de media */
/* pijlpuntjes */
.eapps-social-feed-post-popup .swiper-button-next::after,
  position: absolute;
  inset: 0;
  margin: auto;
  width: 0;
  height: 0;
  position: absolute;
  inset: 0;
  margin: auto;
  width: 0;
  height: 0;
[class*="MediaVideo__Player-sc"] {
Please replace your current CSS code with the new one and let me know if you like the result :slightly_smiling_face:
Thank you! It works perfectly, great job. I’m really happy with the result. :slight_smile:
Amazing, you’re always welcome!
By the way, we’d like to invite you to participate in our September Contest, where you can win a 6-month extension for your subscription - September Contest: Best AI Feature Ideas Win 6 Months FREE!:wrapped_gift:
