Problem with referring program
Anyone having problems applying the $15 discount code from referral to a monthly-paid plan?
2 months ago I used one, it worked fine. But at the moment it seems to work only with anual subscriptions. If I select any anual plan, the discount is accepted. Otherwise the same code gives back a red message “You need to enter a valid discount code.”
Any help with this, please!
Hi @VJ_Map9 :wave:
We are ecstatic to see you here! Welcome :tada:
I see that you’ve created a support ticket and my colleague Irene has started working on your request. In the last reply, Irene asked to specify the plan you are going to purchase.
Please send this info to Irene and she’ll gladly assist :slightly_smiling_face:
