Would be nice to have an option for a popup window for Read More link in Carousel view (and possibly other views). This would allow to have a predefined vertical length without having to scroll when a user clicks on it.
Hi @Kristina_Karlova and welcome aboard ![]()
Do I understand correctly, that you’d like a full review to be displayed in a popup after clicking on Read More button?
Yes, correct. Many other Google Review widgets work this way, would be great to have such an option.
Got it!
Happy to tell you that our devs are currently hard at work on this feature! Rest assured, we’ll make sure to provide you with updates on any progress right here ![]()
Thanks a lot for sharing your feedback with us ![]()
@Max Just to clarify, by “popup” I did not mean a new popup window, but rather a modal popup box within the same window.
Thanks!
It should work the way you’ve described. We’ll keep you posted here ![]()
