Is there a way to, instead of opening the link in a new page, have the “Read More” link open the full post in a pop-up?
Hi there, @Manish_Chaudhary ![]()
I’ve checked your widget and see that you’ve already found the solution
Let me know if you have any questions left ![]()
Could you please send me a link to the page where your widget is installed?
Thank you for your support.
Here is the link to the page where the widget is installed: https://nephrology.edu.au/
I found that the “Read More” link only expands posts when clicked directly on the text. If I click anywhere else near the “Read More” area, the full post opens in a pop-up as expected.
Let me know if you have any other questions.
Regards,
Manish
Thanks! I’ve passed it on to the devs and will get back to you once the solution is ready ![]()
We’ve added this code to the Custom CSS field on the Appearance tab of your widget’s settings:
[class*='CardContainer-sc'] [class*='Block__RegularBlock-sc'] [class*='Text__Container-sc'] [class*='Text__Control-sc'] {
display: none;
[class*='CardContainer-sc'] [class*='Block__RegularBlock-sc'] [class*='Text__Container-sc']::after {
content: 'Read more';
rgb(17, 17, 17);
opacity: 0.7;
cursor: pointer;
font-size: 16px;
[class*='CardContainer-sc'] [class*='Block__RegularBlock-sc'] [class*='Text__Container-sc']:hover::after {
text-decoration: underline;
Please check your widget and let me know if you like the result ![]()
Thank you for your help with this. I’ve just checked the widget, and the “Read more” functionality works perfectly.
I appreciate your quick and effective solution.
Best regards,
Manish
Awesome, you’re always welcome ![]()
Could you please check why the linked post on the website has not been updated, however, the one in my elfsight widget has been updated?
On the elfsight app (https://dash.elfsight.com/widget/0ef793f3-2086-44b1-98ad-717bb4dedd0b)
On the website (https://nephrology.edu.au):
Could this be looked into urgently?
Regards,
Manish
I’ve checked your website and see that this post is displayed now:
Please check it out and let me know if everything is fine now ![]()
