Popup scheduling - reuse popup - change schedule - not showing
I had a popup that I used on a site for thanksgiving closure, which was scheduled to show for 2 days then stop showing. This worked great.
I need to reuse this popup for Christmas closure, so I edited it and changed the schedule to today through wednesday. However I can’t get it to show.
I duplicated the popup because I can’t wait for an answer but I saved the old page with the original popup here for you to review: Arborist Services of Kalamazoo - ISA Certifed Arborists
I don’t know if it is a bug or there is a typo. If you could review I’d appreciate it.
Note, when I duplicated the popup, made a minor text edit, saved and installed it on the homepage (replacing the previous popup code above), it does show.
Hi there, @Hugh :wave:
The thing is that you’ve hidden this widget from your website in your dashboard. If you choose the “Show on website” option, the widget will appear again:
Let me know if you have any questions left :wink:
I’m such a dummy. Thank you @Max :pray:
No problem at all :wink:
