We distribute for multiple businesses and are working to create individualized maps for each of them. Currently the amount of room given for images/Logos within the pin is quite small and we would like to be able to fill more and also have access to things like border width etc.
Hi there, @R_E_Distributing and welcome to the Community ![]()
As for the border width, you’d like to control the width of the blue area in the example, right?
Yes, I would love for my logos to be a bit bigger!
Got it, thanks!
This code will help you change the size of the marker:
[class*="marker__MarkerBody-sc"] {
width: 38px;
height: 42px;
To control the width of the blue area in the marker form the example, you can adjust the size of the marker icon and its position, using this code:
[class*="marker__Icon-sc"],
[class*="marker__Icon-sc"] img {
width: 30px !important;
height: 30px !important;
top: 4px;
Both codes should be added to the Custom CSS field on the Style tab of your widget’s settings ![]()
