Issue description: How do I change the pin marker color when a location is selected? The current one is dark red, and I want to change it beige when the location is selected.
I tried the solution suggested here, but the logo is totally covered by the new color.
Link to the page with the widget in question: https://73e495879a3241a1867d1ffcafcdedc0.elf.site
Hi there and welcome aboard, @MelvinNeo ![]()
This CSS code should help you:
.active [class*="marker__Container-sc"] [class*='marker__MarkerBody-sc'] path {
fill: beige !important;
Please try it out and let me know how it worked ![]()
Yes, it works!
Thanks, Max. ![]()
Awesome, you’re welcome!
In the meantime, we’d like to invite you to participate in our new contest, where you can win a 6-month extension for your subscription - May Contest: Create a Caption for Our Photo and Win 6 Months FREE! ![]()
Since we’re at it, how do I increase the size of the marker icon without considerably increasing the size of the marker?
Hi, @Max
That works! Thanks.
Awesome, you’re welcome ![]()
