Would it be possible to get a permanent display that also changes after time XY.
Hi there @Fri
Thank you so much for adding your idea to the Wishlist!
Could you please describe your use case in a bit more detail? How long the same notification should be displayed? When should it be changed?
This info would help us better understand your idea
