I often build forms that require Lists to be added into dropdown, that have been built on a spreadsheet.
When entering into the dropdown on here, I have to manually enter each option, which is time consuming.
When I started using Form Builder, this was an option. It would be fantastic to have this back, and save a massive amount of time, and frustration
Steve
Hello there, @Steve85 ![]()
This is a great idea! Let’s see if it catches on with the community ![]()
Max
Was there ever any movement on this I’m a month or so away for building the new Forms, that will need mulitple input of different lists from Google Sheets
Steve
Hi there, @Steve85 ![]()
Unfortunately, we don’t have any news regarding this idea. I am sorry!
The thing is that we consider requests based on their complexity and number of votes. At the moment, we have a lot of requests with the higher priority level and our devs are focused on them.
If this idea gains more votes, it might be prioritized sooner, but it’s hard to give any predictions for now.
We’ll update you here in case of any progress ![]()
What’s strange/a little annoying, is that you had it. When I first started using Elfsight I used to load lists from Excel.
Then for some reason it was switched off
Hmm, it’s possible to upload lists of locations in our Google Maps and Store Locator widget, but I’ve talked to the devs, and they’ve confirmed that we’ve never had this feature in our Forms.
As a workaround, you can consider using the AI Generation of the form:
Here you can describe your use case and paste the list of options for the dropdown. However, keep in mind, that the generated form will completely replace your existing form ![]()
Please let me know if this explains things or if you have any questions left.
