We have a use case where we’d love to be able to set the lower and/or upper limits of a slider based on the answer to a previous question.
As an example… our question on slider A might ask ‘How many licenses do you have?’ with boundaries of 1 to 1000.
Slider B asks ‘How many of licenses would you like to update’… with boundaries 1-1000.
Ideally, if someone answers slider A with the value 321, then there is the back-end option for this to becomes the upper boundary of slider B.
I.e. slider B dynamically becomes 1-321 instead of 1-1000.
- Slider A: value 321 range 1-1000
- Slider B: value not set range 1-321
If the user were to move slider B to 234 then slider 1 minimum could (though backend configuration) become 234 (without changing the value)… such that the boundaries were:
Slider A: value 321 range 234-1000
Slider B: value 234 range 1-321
If the user moves Slider B to 100, then Slider A’s boundaries change again.
Slider A: value 321 range 100-1000
Slider B: value 100 range 1-321
Note that by these being back-end configuration options to set the lower or upper boundary from an answer rather than ‘hard-coded’, care must be taken to ensure that hints are used to describe what’s going on so.
