Option to remove clickable elements
Can we request the option to remove the clickable option on phone number & map, retaining the email & website.
Hi @Gary_Brett1!
You can achieve this using this code in the Custom CSS field on the Settings tab of your widget’s settings:
a[href^="tel:"] {
  pointer-events: none !important;
  cursor: default !important;
a:has(.address__StyledAddress-sc-e89cad7d-1) {
Give it a try and let me know if it helped :slightly_smiling_face:
